I am currently developing and using an EDEM API-based contact model. Recently, I created two custom contact models using the API. Each model works correctly when tested individually; however, I found that when both are applied simultaneously, neither of them is activated.
At first, I considered that this might be due to the order of models in the Creator – Physics panel. However, if that were the cause, at least one of the models should still have been applied, so I believe this is not the underlying reason.
Therefore, my question is: is it fundamentally impossible to use two API plugin contact models at the same time? In other words, does EDEM not support running more than one plugin API contact model concurrently?
Thanks in advance!
