I am trying to simulate slot antenna in an infinite ground plane through characteristic mode analysis in FeKO 2025. The design contains 4 slots on infinite ground plane under the condition of multilayer planar substrate.
I set the slot with the "Planar Grenn's function aperture" solution method. In the user guide, it shows that the CMA can be used in aforementioned model, however, it shows the following error "Only MoM solution methods are supported in Characteristic modes".
The thing I can not understand is although there is an error the simulation is finished, however, when I check the results, I can not find anything.
 I really need some advice to solve this problem.
Attached is my design.
Any help will be highly appreciated.
Thanks
