concatenate function does not work with a % field
Altair Forum User
Altair Forum User
edited March 2018 in Community Q&A
Have tried to create a text field that is formed of both fields and added text. One of the fields I need to include is a % number field. Which does not work as it is wrong field format
Have tried to convert this field to a text field using Chr() funtion, but the result is a blank field.
How do I convert a % number to text so that it can be included in a concatenate function?
  • Altair Forum User
    Altair Forum User
    edited March 2018
    Hi Vanessa,
    The STR() function will convert a numeric field to character.  By default, I believe it creates a 10 character long, right justified field.  There are a few options such as length, decimals and padding character to override these, but the easiest option is usually :
    Trim(Str([YourField]))
    Depending on how your decimal is formatted, you might need to multiply by 100 and use the optional characters and use something like :
    Trim(Str([YourField]*100,5,2,""))
    CHR returns the ASCII character for a given number.  CHR(65), for example, returns the character 'A'.
    Steve.
Welcome!
Welcome!
