I am trying to run a particular Proman project with different Tx antenna patterns using WinPropCLI. A simple code to run the project and save the results worked with: WinPropCLI.exe -F "C:\Users\Documents\indoor_winprop_test.net" -A --results-pro "C:\Users\Documents\Results\Run".
But it did not work when I tried to load a pattern using, eg: WinPropCLI.exe -F "C:\Projects\MyScenario.net" -A ^
--results-pro "C:\Results\Run1" ^
--antenna "C:\Antennas\Pattern1.ffe". Could you suggest any modifications or any other resources? Thank you.
Regards
Saurav
