In Older versions may be on or before 2019, If i update mesh locally and regenerate whole solid for the respective component, only Sete Segments corresponding to updated mesh will be lost and other areas (no mesh change areas) Set Segment information is still available.
But in newer versions If i regenerate the solid all the contact elements (setsegements) corresponding to that component are lost even though i haven't changed areas at contact regions.
Is there any way that or any option can we rectify this?
Thanks,
