I have a simulation of several antennas with complicated matching networks implemented as Network schematics.
How do I find the S-parameter coupling between the actual antennas? The only way i can see is to create a task for each possible source and manually compute the coupling to each load. And then assemble a touchstone file by hand from the results.
As an example just create a model with 2 copies of feko's example log-per antenna. Or more realistically 10 copies.
