Hi everyone!
I am setting the size distribution for two particles: DRI and Anthracite. The measured distributions are as follows (in ferret diameter):
Now, when I set this distribution in the EDEM GUI and run my simulation, the particles are not actually created according to the distribution. Rather I only see a single size for DRI, as wel as a (different) single size for Anthracite equal to their physical radii.
So, is there a reason why EDEM is not implementing my PSD? Have I interpreted a setting wrong or is there another window that I cant find where I should activate PSD?
My EDEM settings are as follows:
DRI:
Anthracite:
The lower cap is such that the min radius equals 2.775*0.721 ~ 2mm.
The upper cap is ~9mm.
Please dont worry about my contact radius settings. These are specified such that after the DRI shrinks 25% the contact radius is exactly its inital radius. Similar for anthracite but then with a shrinkage of 10%.
Also, yes I want my contact radius to also scale with the same distribution.
But again, my post-processor shows the following:
Does anyone have an idea what I am doing wrong in my settings and why EDEM is not generating my PSD?
Thanks in advance!
Kind regards,
Jan-Thijn Wijnker
