I am using the Fastener tool for creating the FE representation of bolts (RBE2 for head, BAR2 for body with "bolt (washer 1)" connector control). While creating fasteners using solids (in my case, nuts) as identifiers for FE creation on an already existing 2D mesh, connectors are realized and RBE2 elements are formed even if there is only a single panel at the solid location. For other locations, RBE2s and BAR elements are created properly as per the tolerance. How can I avoid this issue? (Hypermesh version 2023.1)
