HI,
I am using monarch automator version 14.1, in that when i connect the output to my Database, it throws an error SQLNCI10/11 is not registered on your system, could someone give the solution if possible?
Regards,Syed
I think something might be wrong or missing with your SQL Server client on the monarch server.
I did read something in some of the recent Monarch Server release notes that there was an issue with SQL installation scripts, it could be related.
I would contact Monarch support for assistance to ensure you have a good build of the installer and get help with your installation or upgrade.
These links might help also-
documentation on installing sql server native client
https://docs.microsoft.com/en-us/sql/relational-databases/native-client/applications/installing-sql-server-native-client
installer download link for sql server native client
https://www.microsoft.com/en-us/download/details.aspx?id=50402
Also, If Sql Server Native Client was already installed, you might want to try doing a "repair" in add / remove programs - that should fix most problems
I think something might be wrong or missing with your SQL Server client on the monarch server. I did read something in some of the recent Monarch Server release notes that there was an issue with SQL installation scripts, it could be related. I would contact Monarch support for assistance to ensure you have a good build of the installer and get help with your installation or upgrade. These links might help also- documentation on installing sql server native clienthttps://docs.microsoft.com/en-us/sql/relational-databases/native-client/applications/installing-sql-server-native-client installer download link for sql server native clienthttps://www.microsoft.com/en-us/download/details.aspx?id=50402
Thanks Thomas
