I'm trying to make a bunch of filters that look at the first letter of a surname. In 10.5 the following worked:
Code_XL([Last Name])>64
.And.
Code_XL([Last Name])<68
If I try the same in 14.3 I get the validation message Function "Code_XL" does not exist even though I've picked the function from the menu on the filter screen. Am I doing something wrong?
If I create a formula field to return the value using the same function that seems to work OK. I guess I could make a filter based on that formula field but I'd like to know where I'm going wrong with the original filter as I'm going to need to replicate it in a large number of other models.
