Hello All
I am a Monarch 14 user. Does anyone know if it is possible to directly read & write to Excel (or Other) files stored on Google Drive using Monarch Models and Projects.
Thanks,
Al Rice
Hi Al Rice,
For now, Monarch can only get data from FTP, Sharepoint, AWS and Webdav. Thanks
Monarch and altair personal slc reading and writing google sheets
Too long to post to a listserve, see github
github https://github.com/rogerjdeangelis/utl-monarch-and-altair-personal-slc-reading-and-writing-google-sheets
https://community.altair.com/discussion/6385/reading-writing-excel-and-other-files-directly-from-google-drive?tab=all&utm_source=community-search&utm_medium=organic-search&utm_term=monarch%20excel
Note: It is very easy to convert an excel sheet to an R dataframe and then create a google sheet; df <- read_excel("path/to/your/excelfile.xlsx")
PROCESS (I assume you have access to google sheets)
1 set up a googlesheets api and Oath EDIT code below Replace abcdefghij with your Oath Replace abcd with your API myapp is arbitrary client = gargle::gargle_oauth_client( id = "abcd", secret = "abcdefghij", name = "myapp" ) 2 Create google sheet. sheet_new using R builtin irsis dataframe Note gs4_create will automatically overwrite a google sheet if it exists 3 create dataframe, df, from google sheet 'sheet_new and use sql to subset for species=setosa 4 create wpd dataset from the subsetted sheet
