Hello all, I'm working in version 14.2.0.7331 when I go to import an excel file, I select the file, then the table then go to pull the table in (import and tried import and define) and monarch crashes. any thoughts/solutions/workarounds?
thank you
paul
Paul,
Every Excel file or only certain files?
Which version of Excel used for the file creation?
.NET up to date on the machine?
Can you test on another PC and if so do you get the same result?
Grant
