Description: Abaqus generates an error when i run the simulation with kinematic coupling defined with a dependent node set. I am trying to delete this in hypermesh but it is is giving an error message and does not delete the set. If i delete the node set under sets, it also deletes the kinematic coupling.
Product/Topic Name : Hypermesh 2023.1
