I want to use the quality in the statistical domain of EDEM as a response in Hyperstudy, and then optimize the particle parameters. The official staff gave me a video tutorial, and I watched it. It was indeed what I wanted, but I followed along and couldn't generate a CSV file to generate the response. This is the video link: https://youtu.be/TXeqwkpr82o?si=IxlsexZOdlF9fIsQ ;Between the tenth and eleventh minutes, he generated the CSV after testing, but I followed suit and did not generate it;
Figure 1: After completing the modeling in Hyperstudy within the video, a CSV file is generated after running the test;
So based on the above purpose and tutorial, I found a function in EDEM that generates Bin attributes during the simulation calculation process, as shown in Figure 3. I tested and found that after the simulation was completed, this function could generate CSV files. However, even after updating the EDEM settings in my Hyperstudy, I still couldn't generate the CSV format file I wanted, so my Hyperstudy optimization couldn't continue.
Figure 2: Use of CSV function generated during simulation calculation process
Adding this setting to Hyperstudy still does not generate CSV
In addition, when testing this feature, I found that there is an issue with the quality export. The data exported for total and total over time are the same, displaying the quality in the Bin, which is completely different from the total quality in the Bin that I exported for the total time. Is there a problem with this feature?
Figure 3: The two exported data are the same
Figure 4: The results of using Total over time in Bin are different
