I plot several hotspots but when exporting to 3D HTML file, hyperview only exports a few of them:
how can I fix this?
Can you verify with the limitations in the notes? https://help.altair.com/hwdesktop/hwx/topics/file_management/3d_model_export_unity_r.htm#_3d_model_export_unity_r__section_nbf_2y5_qbc
well, based on this information my notes should be considered "contour measurements", and it clearly says "Viewer only supports…", so I would think it should work as I want, but it seems that the amount of notes is also limited somehow😕.
Thank you for the support 👍️
Can you verify they are all activated?
Thank you, I checked it but not all notes are exported. My hyperview model has 27 notes, while the html file only show a few of them (check attached image).
