Guys, can HyperView open results from MSC Nastran hdf5/h5 files? I see it can open Nastran XDB (.xdb) and Nastran/OptiStruct OP2 (.op2), but what about hdf5 which became primarily format for Nastran results? Thank you!
Yes we do support hdf5/h5 results files. Have you tried loading them into hyperview?
As this is simply a specialized container for results, we may not support all setups.
Dear Jason,
We're able to open MSC Nastran .h5 files, but we're encountering issues with NX Nastran .hdf files. I had understood HDF5 to be a standardized format, but it appears there are differences between the MSC Nastran .h5 and NX Nastran .hdf implementations.
Could you please investigate the NX Nastran file format?
Thank you!
We support .h5 and .hdf5 exti
