The first thing I found interesting is that when using millimeter length units in Motionview and coupling EDEM, the EDEM also uses millimeter units. When importing the coupling results into Hyperview, the EDEM model seems to shrink by a thousand times. However, when using meter length units in Motionview and millimeter units in EDEM, the two models become the same size(model overlap). So, I would like to ask, when Motionview couples EDEM, is it always using meter length units in Motionview and millimeter units in EDEM?Here are two comparison pictures
The second question is that I am conducting angle of repose testing in EDEM. When I open EDEM and use a script, I can obtain the results. However, when I follow the tutorial video in Hyperstudy, it seems that the script is not enabled and does not generate a CSV file
Figure 1:Figure 1: Model Reference
Figure 2: Script Settings
Figure 3: No CSV file was generated as a result
