Hello everyone,
I'm encountering an error when trying to use the "Orient wires of coil conductor regions" feature in Flux3D 2025.0
The error log shows the following:
WIRE1 : On each volume of this region, the number of points on the
input faces must be equal to the number of points of
the output faces and to the number of lines between
the input and output faces.
Please, modify the geometry of each volume of this region
to resolve correctly this problem.
WIRE2 : On each volume of this region, the number of points on the
As the error message suggests, I have already carefully checked the input and output faces for the volume regions (WIRE1 and WIRE2). I've confirmed that they have the same number of points and edges, but the error still occurs.
Could anyone offer some advice on what else I should check? Any help would be greatly appreciated!
Thank you,
Leon Lin
