I am currently planing a big simulation that needs to be repeated several times with different excitation sources(voltage sources for farfield calculations, mostly).
Is there documentation on what setups and settings to use to minimize total simulation time?
I assume that if I setup the problem as different configurations in a single model it would compute most efficiently, or are there settings I can change to improve things?
Similarly, are the settings or options different between pure MoM, MLFMM and ACA?
