Assuming I have a beam element, but I am unsure which section to use for design? I want to set the cross-sectional shape of the beam as a parameterized variable, assuming a T-shaped beam, and each parameter of its corresponding beam cross-sectional parameters is given an interval. The cross-sectional shape can also be square or circular, and each value of its corresponding cross-section is a variable. How can this form be used in a parameterized model? I know the cross-sectional size can be parameterized by right clicking, but what about the cross-sectional shape?
