I’m working on coupling EDEM with Fluent. In my case, the domain is rectangular, with the bottom half filled with water and the top half with air. Particles are falling from the air onto the water surface, and I want to study their behavior in the presence of water.
I’m using the default EDEM-Fluent coupling provided by Altair, which works fine for a single fluid phase. However, when I try to simulate two fluid phases (air and water), the simulation crashes. I get an error saying: “Particles not found in EDEM”, and from that time step onward, all particles disappear on the EDEM side.
Has anyone experienced a similar issue? Is there an alternative way or another coupling method that supports two fluid phases?
Any help or suggestions would be greatly appreciated!
