Hello Community.
I would like to calculate a tank in HyperMesh with Optistruct. This tank contains particles that load the tanks. I have set up an EDEM simulation to determine the reaction forces between the particles and the tank wall. I then saved the forces in a .csv file.
I now want to read the external force into HyperMesh and apply it to my model. To do this, I use linear interpolation under Force. However, I have the problem that the forces arrive incorrectly in HyperMesh. When I compare the mass of the particles in EDEM with the sum of the forces in the .csv, the values match plausibly. If I analyze the forces in Hypermesh via Summarize, I get much higher forces here.
Here is a screenshot with the settings of the Interpolate forces.
I took the workflow from this tutorial.
https://community.altair.com/discussion/39688/static-structural-analysis-for-bulk-solids-handling-applications-using-edem-optistruct-and-simsolid?utm_source=community-search&utm_medium=organic-search&utm_term=edem+force+to+hypermesh
