i was trying to finish this tcl that automatically finds the holes and creates rigid and spring elements for that. i am having an issues of creating spring elements.
the issues is 1st set of rigid master node ids are calculated correctly. but 2nd set of rigid master nodes are double in numbers. help me to find hte issue. attaching the script for reference
May you looked instead at utilizing the Connector workflow directly within the core tool?
Help
https://help.altair.com/hwdesktop/hwx/topics/pre_processing/connectors/connectors.htm
YOutube
https://www.youtube.com/@altairhowto /search?query=connectors
They can automatically find mating holes, create the head and body and are quite configurable, without need for creating a script from scratch.
