Hello
I am currently using version 19, but I am trying to adapt to the newly changed UI (v2024).
There are some features that work in version 19 but not in v2024.
It is a normal function of element.
As you all know, in version 19, I work as follows.
Create a 2D shell mesh, select all elements in the adjust option, select the reference element, and adjust the normal to match.
However, this cannot be done in v2024 normal.
After searching many ways, I found that if you disconnect the properties of the surface connected to the element, you can work as above.
(Delete surface)
In order to preserve the surface, I copy the surface and delete the original surface.
In this way, I can use the normal function, but I hope I can work without deleting the surface.
If anyone can help, please let me know
Thank you.
