Hi Everyone,
I am researching the coupling of Fluent and EDEM. Since the particles in EDEM are sphero-cylinders, GPU computing must be used. However, the GPU version of Fluent does not support multiphase flow, so Fluent is computed using the CPU. Will using different processors for these two software affect the data exchange between Fluent and EDEM?
Best regards,
Bai
