Hi everyone, I am having some problems with soft ground vehicle simulation using motionview2024, I followed the tutorial guidelines for soft ground modelling and used the crg file to write the terrain, but I got an error when loading the file, then I tested it using the crg file in the file repository, but there was no sinking when I viewed the simulation results at the end of the simulation run, may I ask what this is? What is the reason for this, thank you very much!
