How Can I run a hyperstudy structural sim for multiple martials (from list) multiple thickness (from list)., using a model trained with material and thickness labels
if i'm not wrong, when you train your model, it reads the data of material and thickness from the FE model, besides the result file.
Although i've never run this prediction, if you provide a FE model with new thicknesses and materials, you should be able to get the prediction using these inputs as well, right?
In theory PAI will read these info from your .fem file, assuming you have parametrized these as variables in HyperStudy.
