Getting the input file name in a PreProcess script
User: "Altair Forum User"
Updated by Altair Forum User
I am currently trying to create  Datapump PreProcess and PostProcess scripts that in the preprocess script will copy a file to a destination file with the same filename as the input file name ie. input file is abcd1234.txt and I want to copy default.csv to \\<destination server>\<destination folder>\abcd1234.csv    and then in the PostProcess script can then rename the csv to a different extension say "abc" for example
The catch here is the Data Pump script is monitoring the source folder \\<source server>\<source folder>\ for any text - ".txt" - files that are put into the folder, so I don't actually know the name of the input file
How do I find out the name of the input file that the monitoring has detected so that I can use it in my PreProcess script, and ultimately pass it into a post processing script
1 - 1 of 11
    OP
    If there is only one input file, you can use the following syntax:
    Dim FileName As String = Log.ExpandMacros("&[input]")
    If there are multiple input files you can use the following code:
    Dim itemList As JobLogItemList
    Dim item As JobLogItem
    Dim n As Integer
    If ExportCompleted Then
      itemList = Log.GetInputItems(ProjectID)
      If itemList.Count = 0 Then ' No input items exist
      Else
        n = 0 'initialize the counter
        For Each item In itemList
            n = n + 1 'update the counter
            FileName = item.location
            log.addevent("Input File: " & FileName)
        Next
      End If
    End If
