Please could you help me to indicate, what is the Python code needed for querying CBUSH element forces in Hyperview? And is it possible to export the .csv file as the Table module does?
Many thanks,
LDS
sorry to deviate a little bit your question, but depeding on the solver you're using, for example, OptiStruct, it is possible to request directly the element forces for the CBUSH's in ASCII format (OPTI output request) from the solver run with no need of extracting these later.
