In EDEM altair, how to create the cylindrical zones with different radius to capture particles around the cylinder for clipping? There is only option to select clipping planes in the clipping tool in analyst.
The clipping planes only work as planes along a specified axis, they can't be used to create a cyindrical shape.
However yuou could use the imported geometry bin groups. If you create a CAD shape that you want you can import this in the Setup Selections in the Analyst. Then you can colour and display particles in this area.
Video shows the process.
Regards
Stephen
