I started with the hyperstudy example provided among the 2D examples. However, when I try to run the definition, I consistently receive an error. The test is unable to write, execute, or extract, and I'm unsure why.
below is the nature of the error message i am getting:
755 Error : Failed to copy model resource ( C:/Users/gordon_asante1/hyperstudy/MDO_EMOTOR_STUDY/MDO_EMOTOR_Case2/HyperStudy/1_FluxMotor/Connector_FM_Hst/Connector_FM_Hst ) to ( C:/Users/gordon_asante1/hyperstudy/MDO_EMOTOR_STUDY/MDO_EMOTOR_Case2/HyperStudy/approaches/setup_1-def/run__00001/m_1/Connector_FM_Hst ) with error ( The system cannot find the path specified
749 Error : Failed evaluating expression ( r_8 ) with error ( Failed evaluating ( Base speed::Control angle (deg) ( r_8 ) ) ) in ( CTRL_ANGLE ( var_23 ) ).
Thank you in advance for your support!
