I am studying the motion of long flexible bodies in a rotating flow field using coupled Fluent and EDEM calculations with an Eulerian coupling interface. The long flexible bodies are modeled using the fibers bonding model in EDEM2025, but some parameters are highlighted in red and I'm unclear about the cause. The figures below show the parameter settings for the long flexible bodies and the coupled calculation time step settings for Fluent-EDEM.
The simulation results include residual plots and a drag force plot. The coupled calculation proceeds normally from 0 to 0.00065s, but the calculation suddenly diverges after 0.00065s. Do you have any good suggestions for the cause of the divergence?
