Description: [I want to make a Cumulative Distribution function plot based on particle shape using aspect ratio. Can i import this out of EDEM someway? I know for the aspect ratio I would need
AR = x_Fmin / x_Fmax
For a pair-wise gs,
x_Fmin = diameter of the bigger particle
x_Fmax = d_big + d_small - overlap
The main issue is that a lot of the particles I used are a variety of shapes and sizes. ]
Product/Topic Name : [EDEM 2022.3. ]
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
