Hello
I keep getting this message when i run simulation on HPC after 10 hours i dont know why.
one possible resolution i am thinking of trying is specifying the screen resolution when i connect through vcl to hpc.
Can you please tell me where can i find /.altair config file in the installation directory. i tried looking for it
here -
/DEM/altair/EDEM2025/altair/
but i could not find it
The error is given bellow.
WARNING : Argument Conflict : grid option is not applicable to GPU CUDAsolvers. Option will be ignored.qt.qpa.xcb: could not connect to display 10.1.16.111:11.0qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" eventhough it was found.This application failed to start because no Qt platform plugin could beinitialized. Reinstalling the application may fix this problem.Available platform plugins are: minimal, xcb.DEM/altair/EDEM2025/altair/EDEM/bin/edem:line 21: 527487 Aborted                 (core dumped)"${SCRIPT_DIR}/edem-bin" $@
Just to let you know simulation works fine. it used to run for more than 10hr. but sometimes it staops at 10hours and i get this message.
If i reinitiate it after an hour the simulation runs fine. so i am confused how to even resolve this. I can't have an unreliable case file running that stops suddenly like this.
