I am a new Monarch Classic user and I am trying to convert a FA report into a table. Each Asset record contains either 2 or 3 lines where the 2nd line containing the asset serial # is option and missing from most records. While I am able to trap the desired fields from the 1st (detail line) and 3rd line (append), The filed from the append record is showing up as 'null' of the 1st asset on the report (has all 3 lines) and appending itself to the 2nd asset on the report. This one off is consistent for all following asset record.
What am I doing wrong and how do I correct it.
thanks.
Mike
