I'd like to create a note (from hotspot) where the name of the material appears for stress on elements.
When the property is applied on the component, the material name appear with "{entity.materialname}" on the description text field.
However, "{entity.materialname}" shows "N/A" when the property (and so, the material) is applied to the element, even if selection of elements by material using the "result" tab works.
Do you have any idea to fix it ? I'm editing the note to manually enter the material name, but it isn't a satisfactory solution.
Thanks,
Pierre
