ERROR: Processing data for Spline [id=301001].
I have a spline which i have given as an input to a motion. But the above error is showing up. Please help, i have attached the mdl file
Hello @Shiva Kumar The curve values needs to be in increasing order, and the same error is seen in the .log file See attached images. You can make the values increasing and try, and that should resolve the issue.
Your curve values:
Hope this helps!
Thank you Sir, ill resolve it
