Hey
I am trying to make a plate fall from a height of 0.0105m with an initial velocity of 20 m/s. The time required for the plate to reach the ground is 0.5 milliseconds.
If i run the simulation in Windows and give this in the environment with this as motion defination
Gravity will be applied on the plate in -ve z.
The gravity vector will be applied to the plate as it falls down.
Now, if I do the same thing on Linux and do not give acceleration in motion definition,
It will not work. It was working only when I defined a gravity acceleration in the acceleration part of the motion
Why so?
Is this a bug in EDEM, or am I doing anything wrong here? Please let me know.
In both Windows and Linux i am using EDEM2025.
