cannot run simulation with 2023.1 version in Inspire Cast
I ran the simulation with the same boundary conditions on both versions 2022.3 and 2023.1.
However, only version 2022.3 worked, while version 2023.1 gave an error as shown in the screenshot. I also tried using the result file from version 2022.3 in version 2023.1, but the error still occurred.
Could you please help me figure out how to fix this issue?
Hi! @Minh_169
Can you send me your setup model so I can check on my end regarding the issue?
You can see detail in below link.
https://drive.google.com/drive/folders/16OScWkaX9VK059MmTmeor5BKoqs6s31i?usp=sharing
Thank you so much.
Hi @Minh_169,
The reason for your run failure was the setup configuration. Do not consider first value of pressure to be 0. This is why it is throwing you an error.
Hi @Minh_169,
Hello @Minh_169,
The versions of Inspire Cast you are using are pretty old. There are various upgrades in configuration from 2022.3 to latest 2025. I suggest you to upgrade the version to 2025 and check. if it still fails, let me know.
