Create Surface Line does not work?
User: "Schiggy_1"
Altair Community Member
I am having trouble drawing lines on a working surface as intended.
As you can see from the attached pictures, choosing a slightly different end point causes the line to jump out of the surface. While endpoint (5, 4) works as intended, endpoint (5, 3) is completely outside the surface. Could someone please explain this to me?
Application: CADFEKO Version: 2025-4963 Date: 2025-2-3
1 - 1 of 11
