Hello everyone,
I’m currently working on a 2D axisymmetric simulation in Altair HyperMesh where I want to model the nonlinear penetration of a hard cutting edge into a softer elastomeric sealing material. The goal is to capture the realistic contact behavior during the initial intrusion and deformation phase.
I came across a tutorial from version 2021 where the contact between two lines was defined using a line-to-line contact approach. However, that tutorial was based on the older user interface. (OS-T: 1394 Axi-Symmetric Ball Joint)
Now I’m working in Altair HyperMesh v2024 and I’m having trouble locating the corresponding feature.
Where exactly can I define line-to-line contact in the new interface in v2024?
Is there any updated workflow or specific card I need to use in the current HyperWorks environment?
I’ve attached an image of the geometry I’m trying to simulate for better understanding.
Any help or pointers to updated documentation would be greatly appreciated!
Best regards
Simon
