Description: Would love to create a strucutred mesh for later data exportation
Product/Topic Name : Altair Hypermesh CFD 2024.1.0.30
Im doing a project where I use the Inlet and a plane far behind a model data to calculate the aeroydnamic forces and Drag/Lift coefficient based on Navier-Stokes equations integral form.
Already did a simulation but found out that as I'm using the usual meshing method I get unstructured data and its impossible to use this data with the method im using. So I was wondering how could I create a structured mesh so I dont have this problem, if it isnt possible I could just export lines of data with Rake function in Post-Processing but for now I'd rather avoid that.
I only need a structured mesh behind the body and in front of it for data, the model can have unstructured data if it may cause troubles.
