I'm getting the "A Segmentation error occurred. Do you want to save your model?" error message immediately upon opening my file.
Is there any way to fix a file that displays this message?
I've lost my whole HM project becasue of this error.
Help.
Hi, Richard,
Which version are you working with?
I would recommend to check this Article, Removing HyperWorks Settings Files might help:
Arthur
I'm using HM2025.
I've deleted all the usual files in the working directory but this does not help.
Segmentation error again imediately upon file opening.
Is there anything else i can do?
Thanks.
After receiving the error message, did you save the model and continue using it? If you keep getting errors, the model may be corrupted. I recommend that you save the model you are working on periodically with different names.
