Hello Community,
I am working on simulating mud (limestone particles <4mm mixed with water) flowing through a chute using EDEM software. However, I encountered challenges while trying to adjust the material's angle of repose (20 degrees) and its properties.
Initially, I created the material using the GEMM Wizard, but I couldn't modify the angle of repose or the JKR coefficient. I also attempted to create the material via the Bulk Material menu, but it seems these attributes are not available there either. While exploring the soil starter pack installed in EDEM, I noticed that the sticky material provided has a significantly higher angle of repose than required for my simulation.
Could anyone guide me on how to adjust these parameters to accurately simulate this material in a transfer chute? Additionally, is there a tutorial or method to simulate the cohesive bonding effect of water with limestone particles?
Thank you for your time and insights. I truly appreciate your help!
