Keyboard shortcut is not working if I try to switch entities (Elements, Surface...) to select
User: "Yogaraj_D"
Altair Community Member
Hello ,
I have been using both the new version of Hypermesh V2024 and V2025 since it launched. In both the version I found a bug which happens when I change or switch between entities through keyboard shortcut to select entities like elements(E), surface(S), lines(L) etc.., in the Organize tool. Except Material (M) none of them won't work if you use keyboard shortcut. But in the drop-down list you can see all of the entities with the shortcuts underlined.
I have attached reference image below…
Operation: Organize
Issue : Not able to switch between entities through keyboard shortcut
Altair team pls take this in concern and do update.
Thanks,
Yogaraj Duraivel
1 - 2 of 21
