🎉Community Raffle - Win $25
Join and Win
User defined function not working
User: "sudo"
Altair Community Member
I have created a sample user defined function used in a solver variable in motionsolve.
Here is how I did it:
Here is the py code:
I tried to run the simulation and plot the results, however I am getting a value of 0 in the primary pulley radius throughout the simualation.
1 - 1 of 11
    User: "GTT Adam"
    Accepted Answer
    Hi @sudo,
    I believe that an array must be returned and not a single parameter. If we look at the example provided in MV-1203, they show the following syntax:
    def REQSUB(id, time, par, npar, iflag):
    [D, errflg] = py_sysfnc("DM",[par[0],par[1]]) ## sets "D" as piston
    displacement mag
    result = [0,D,0,0,0,0,0,0] ## lists results for output
    return
    return result ## sends list with results to motionsolve as
    output
    In this example, we can see that the distance measurement is returned as an array called 'result' with 8 inputs. I would try to return your 'result' as an array as well.
    Hope this helps!
    Adam Reid
