Is it possible to couple Inspire Cast with HyperStudy? If yes, how can I achieve that?
Hello @Minh_169 ,
I can share the demo package of the study I worked on.
https://ftam1.altair.com/message/jgjBqllX0Fo9FtFNjalF9H
However, based on your need, you might have to discuss this with HyperStudy expert . Let me know if you are trying to execute certain study.
Hi @Minh_169,
As of HyperStudy 2025.0 version, Inspire model connection is not available.
However, we will check with the HyperStudy development team as they were working on it as part of future releases.
Also, if you can, then kindly provide the use-case details, may be, we can suggest a workaround for your requirement with respect to performing design exploration.
Many thanks.
Kind Regards
Garima Singh
Engineering Data Science
Hi @Minh_169
To elaborate the answer, Hyperstudy coupling is not possible in Inspire Cast user interface. However, You can use Inspire Cast + Hyperstudy for DOE. Based on what you are trying to achieve, I can help. One of the case study I have worked on is the gate optimization using Hyperstudy based on Inspire cast setup.
Hi @MilanRaval
Could you please guide me through how to use Inspire Cast with HyperStudy for DOE in detail?
Hi @Huyen ,
Inspire Cast 2025.1 includes a limited DOE functionality built-in.
