I face a problem in a model that I build. I have a motorcycle as the example of Altair, but with different mass and inertia properties. I have the problem where I want to make a 3d analysis but I can't keep the motorcycle stable because of not handling the motorcycle as it should be. The control of it I believe is the main reason. I started to test different values of kp,ki,kd and look ahead time, but I couldn't find the solution. Is it possible to find a solution in this problem?
Thank you in advance.
