The process of the code is a plane, then set the local mesh size, and then export it as a NAS file. I adapted it based on the records, but the code generated by the interface still reports an error in the end.
Hello, SFasfAS.
Hope you're doing well.
Which version of HyperMesh are you trying to run this script on?
Best regards,
Humberto Mendonça
