Beginner here. I'm trying to mesh the model attached with a hex mesh. I gather I need to create a 2D mesh first. When I try and use the "BatchMesher" option, it does nothing. It doesn't come up with an error it just doesn't do anything. Any ideas?
Can you please share the model again or share a screen grab?
You might also want to check out these resources for hex meshing
Training
https://learn.altair.com/enrol/index.php?id=737
YOutube
https://www.youtube.com/%40altairhowto/search?query=hex
Ahh right, this one. I would recommend either slicing the whole solid into mappable solids. Or make cross section slices mesh, drag and morph.
Here are some resources on solid meshing and morphing
https://learn.altair.com/course/view.php?id=737
Youtube
https://www.youtube.com/%40altairhowto/search?query=solid%20hex%20mesh
https://www.youtube.com/%40altairhowto/search?query=morph
Help
\https://help.altair.com/hwdesktop/hwx/topics/pre_processing/geometry/surfaces_drag_unity_t.htm#meshing_hex_c
https://help.altair.com/hwdesktop/hwx/topics/pre_processing/meshing/meshing_solid_map_unity_c.htm?zoom_highlight=map
https://help.altair.com/hwdesktop/hwx/topics/chapter_heads/morph_r.htm
Here as some pictures.
